ANG3CHEAPSHOT
- 26
- 18
- California
I’ve got a 2003 M1123 with a front electrical winch. I bought the controller and my winch only seems to let out but not retract. Has anyone had this problems or have any recommendations to fix?
You purchased the wrong controller, the one for the milemarker hydraulic winch. Not a big deal. You just have to change the wiring on the winch side or controller side, your choice. There are only 3 wires. Pretty simple. Good luck.I’ve got a 2003 M1123 with a front electrical winch. I bought the controller and my winch only seems to let out but not retract. Has anyone had this problems or have any recommendations to fix?
Ok thanks. Not sure exactly which one I’m supposed to buy. I bought the 3rd one in the picture Crapgame posted. It’s black with the 3 pin plug. I’m going to take it apart and switch the wires and see if that works.I’ve got a 2003 M1123 with a front electrical winch. I bought the controller and my winch only seems to let out but not retract. Has anyone had this problems or have any recommendations to fix?
Ok I bought the 3rd one in the pictures you posted. I’m gonna follow the instructions and switch the wires and see if that works. Thanks.Milemarker Hydraulic Winch uses the yellow plastic handled 3 pin cannon plug controller. Part # 12469356-2 NSN: 6150-01-475-8835
The A0-A2 HMMWV Warne electric winches use the black rubber coated handle with toggle switch, and square box 3 pin connector (looks like for the Cadillac Valve time delay Module) controller. (Country's photo) Part 12338495 NSN: 2590-01-214-1566
Some of these black rubber winch controllers have the 3 pin cannon plugs Part# 12447171 NSN: 2590-01-448-1105 Seco Parts Photo:
Modifying the Part #12447171 black rubber handle winch controller to work with the Milemarker Hydraulic:
M1038 Mile Marker winch troubleshooting
For anyone trying to disassemble the ITT cannon plug here's a side-view: https://secure.ittcannon.com/mc/PdfDrawingGenerator/CA3106E14S-1PBF80.pdf Thanks. Been looking for that diagram. However, I still don't see how to take the black winch controller's plug apart to switch the wires. I've...www.steelsoldiers.com
Yeah so that’s the one I have but it won’t retract. Only lets outThat 3rd one is the proper one...no need to switch wires for the Warn electric winch.
Put a picture of your winch on here.I’ve got a 2003 M1123 with a front electrical winch. I bought the controller and my winch only seems to let out but not retract. Has anyone had this problems or have any recommendations to fix?
