1986 chevy cucv m1008
Davomoto
I have a 1986 chevy cucv m1008 with a 6.2 in it. It has been converted to 12 v. When I bought it it didn't have a starter with it. I bought a 12 v starter for a 1986 chevy k30 with a 6.2. The starter wouldn't engage the flex plate. I had to machine the starter mounting surface to make it work. I have had the truck for 3 years and I'm on my third starter.Is there a starter out there that doesn't need to be machined or is the proper starter for the 12 v application.?
Davomoto
Have you checked the flexplate for any damage?
Thanks for responding. The flex plate is in good shape. It was installed just before I bought the truck. I don't have contact issues. The starters just fail. This time it is the starter drive.
cucvmule
collector of stuff
1,165
597
Crystal City Mo
Did you modify all the starters, and why? How was it modified, I do not see a reason to do that unless the wrong starter has been used. The diesel starter is different from the gasoline starter.
Are you using the front starter bracket that goes from the starter to the engine block? Are you using the proper starter bolts for the 6.2 starter, they are not the same as a small or big block Chevrolet?
nyoffroad
719
Rochester NY
First off when the Gov. ordered these they specified that no matter what production year it was made in it would use 1984 parts. I doubt this is the case but GM made a change in flywheels between 84 and 85 for 6.2L, perhaps they did the same with flex plates?
What type of "machining" did you have to do?
LT67
511
Bowdon, GA
Not the same bolts if I'm correct
LT67
511
Bowdon, GA
How are your batteries connected? Pos to pos and neg to neg or are they crossed?
Davomoto
Are you using the front starter bracket that goes from the starter to the engine block? Are you using the proper starter bolts for the 6.2 starter, they are not the same as a small or big block Chevrolet? I only modified the first starter. I machined .170 off of the starters mounting surface. I have purchased the starter manufactured for the 1986 chevy k30 with a 6.2 diesel. I reuse the nose cone off of the first starter I machined because none of the starters I purchase will make contact with the flex plate, including any aftermarket gear reduction starter. I am using the bracket supplied but slit at the engine mount bolt hole to compensate for the machine work.
Davomoto
I machined .175 off of the starters mounting surface.
Davomoto
Find an original AC Delco 24v starter and have it rebuilt with 12v parts. Be sure to install new bolts and front brace.
I was told that the 12 v and 24 v starters had the same nose cone on them. Is that not true? If that works I'll buy a 24 v starter and rebuild it to 12 v . Thanks.
Davomoto
Nope.
You have a 1984 CUCV M1008.
The Army didn't want the hassle of model year changes, so they required that all CUCVs be built the same. When you need parts, you want 1984 parts, no matter if your truck was built in 84, 85, or 86.
Thank you so much. I had a parts
Nope.
Two days ago an employee at O 'Riellys told me that in 1984 chevrolet did something different with their flywheels but wasn't sure if it pertained to their flex plates. I will definitely look into the differences. Thank you very much.
nyoffroad
719
Rochester NY
Hmmn, I thought I brought that up in post #7:) I hope it's that simple!
