muttly
- 44
- 13
- Cloverdale IN
Has anyone installed a phillips temro 1000watt block heater in their 6.2 engine? I put one in my m1008 last year and never used it. Installed one in my M1009 last month and it failed right away. I then checked the one in my m1008 and it was open (infinite resistance) also. I requested and received a replacement heater but before I installed it I made a few checks. The new heater had 14.8 ohms resistance and drew 8.5 amps. I filled the cooling system with new 50\50 antifreeze drove around until the engine was warm. I topped off the radiator the next day and energized the heater with a 110 volt 60 hertz GFCI circuit. Checked it the next day and found the heater failed open again. The defective heaters were installed as per instructions and show no outward signs of damage. I have contacted the factory in Minnesota and they confirmed it was the correct heater for the application, and have no answer as to why they have failed. I suggested that maybe the 1000 watt heater was too much and was told to try the 600 watt heater. My confidence in this product is waning and before I take another glycol bath I thought I would check for feedback from the CUCV gurus.
