Thumper580
- 210
- 43
- Virginia
Installed new battery cables. Got them from BatteryCablesUSA. Great site. You specify every part of the cable based on your application. I swear the truck starts better.... Also installed a 24-12v converter and a USB/cigarette lighter console. Will mount the console tomorrow.
The batteries don't seem to go anywhere as far as I can determine.... I have a disconnect behind the USB console.How do you keep the batteries from bouncing around and how do you turn on and off the converter?
Rocking and a sparking, CAMO
Strongly recommend stock HMMWV battery hold down hardware. Inexpensive security for a short or free floating batteries during a rollover...The batteries don't seem to go anywhere as far as I can determine.... I have a disconnect behind the USB console.
Any drawings or other information on your new heat setup WhoMe?Final Got The New Heat All Finished. The new heater pumps out so much heat it melt the hose. So back to the drawing board and this is my new idea for it. But the heater pumps out so much heater I can drive with no doors in the winter now, which is crazy![]()
Wow, what heater retrofit is this?Final Got The New Heat All Finished. The new heater pumps out so much heat it melt the hose. So back to the drawing board and this is my new idea for it. But the heater pumps out so much heater I can drive with no doors in the winter now, which is crazy![]()
Hmm, sell this as a retrofit kit?Also the new hose I use are from https://www.plastixs.com/categories/hot-air-hoses-high-temperature-hoses They say the hose can go up to 500°F before melting.
