- 879
- 519
- 93
- tucson AZ
Yes, will do. Suspension is top of the do-list. So far, I deleted the lower leaf from the rear spring pack as the static load on the rear axle is only 4560 lbs (stock was 6240). That was just to set the ride height. Next step is to remove the front shocks then test to baseline the suspension response then work it from there. It is going to porpoise and go bouncy, I get that, but its just a measurement.OK, I'm seriously jealous of what you're doing. While I don't need the cage and such, I'd love to be able to move across the Nevada desert trails at more than a crawl. Please keep this thread up to date with your mods especially with suspension.
And I love Tucson, lived there ten years - 1995-2005. At one point, I had my lifted Bronco dragging a station wagon back ONTO Reddington Pass, and another time playing with a Deuce in the area. But it's changed since then...
shock... lol..... unless you upgraded shocks already....... there is little to nothing in the OEM shocks when it comes to "shocking". They are mega soft. Granted they also have a limit strap effect to themYes, will do. Suspension is top of the do-list. So far, I deleted the lower leaf from the rear spring pack as the static load on the rear axle is only 4560 lbs (stock was 6240). That was just to set the ride height. Next step is to remove the front shocks then test to baseline the suspension response then work it from there. It is going to porpoise and go bouncy, I get that, but its just a measurement.
Yep. We used to also weight each corner. It's part of the equation as well for baseline.Right - without the extra rear leaf, softer rear suspension especially without a normal load. And removing the shocks allows defining suspension travel limits. That can be done without driving - somewhere I've got an old book on setting up suspensions for race cars. Race trucks are the same, just a lot larger. If I remember correctly, it entailed getting the whole end of the vehicle in the air at the frame to test full droop to full compression travel of one corner at a time. The droop-to-compressed included steering axle wheels at full left, right and center positions. Can also measure bump steer, interference with hard parts, and other aspects for the front when in the air. Rear was much simpler, just up/down, maybe fore/aft travel.
There's several interesting discussions about shocks fitment and LMTV/MTV - I googled "lmtv fox shocks" and came up with some hits on this site and a few others. This one provides interesting technical on how and why to select valving and a number of manufacturers:
Somehow I got old and I have problems climbing into my M1008. How in hell do you get in and out of that monster?Out & about testing stuff.View attachment 824099View attachment 824100
.Somehow I got old and I have problems climbing into my M1008. How in hell do you get in and out of that monster?
For the moment, I climb up and down the tire treads. Sooner or later I will hang a chain more or less where the step was. Am thinking of a transfer case chain: something flexible so it does not interfere when the cab is tilted, but stout. I am open to suggestions, however.Somehow I got old and I have problems climbing into my M1008. How in hell do you get in and out of that monster?
You could mount a small fold up ladder and a grab bar on the cab wall behind your drivers door. When you want to get in just reach up and pull it down "like a set of attic stairs". When your up in the cab you just reach behind you and pull it back up and lock it in place.For the moment, I climb up and down the tire treads. Sooner or later I will hang a chain more or less where the step was. Am thinking of a transfer case chain: something flexible so it does not interfere when the cab is tilted, but stout. I am open to suggestions, however.
Not an RV, rather, a Commercial Vehicle. You see, in AZ anything one-ton payload and up is commercial. No matter that it has only 2 axles. You get to choose what the vehicle GVW is, with 8000 lbs being the minimum. The weight fee portion of the registration is based off that.. When the inspector looked at the truck at ADOT facility, he declared it a one-ton pickup. Not one to argue with official-types, I said ok. Eight thousand pounds he asked? No, 15,750 GVW please. An earlier pass over the truckstop scales showed 13,600 so I allowed for some extra.I noticed you already have it plated in AZ? how did you manage that before it is an "RV"? (im also in Tucson and Have an MTV M1088 project). Just trying to understand the easiest path how to get these things registered in AZ.
Are those 14 20sOut & about testing stuff.View attachment 824099View attachment 824100
They look like 16.00s, but I could be wrong.Are those 14 20s
