2 1/2 ton windshield frame to m37
BKubu
1,224
Gaithersburg, MD
The windshield glass/framework is the same. I am unsure if the A pillar is identical. I've never owned an M37. I do know that I purchased replacement windshields previously from a company that sold M37 parts exclusively. That's how I know the windshield glass/framework is the same.
G744
4,018
Hidden Valley, Az
M35-type glass frames will fit the M37 no problem. I have seen some from M35's that had the wiper holes offset to the side a bit, but that is no biggie.
DG
Ferroequinologist
Resident railroad expert
748
Liberty Hill, SC
I put new m35 inner windshields in my m37. They won't close all the way and the latch at the bottome won't catch. I measured the top of the frame and there is almost a 1/8in difference in the height above the glass on the m35 frames I got, and the m37 frames I took off. I am going to probably switch the upper parts from the old windows to the new ones. It might just be a brand thing too, the ones I have are Korean replacements
Black Ops
98
Colchester, VT
I’ve installed a couple sets of Korean windshields in m37s with no issues. As mentioned above some 2.5 tons had wipers offset to the center of the truck and are not as good a fit when it comes to the vacuum line location in a Dodge. The windshields with offset wipers were on earlier deuces.
20,468
Different Koreans maybe?
Ferroequinologist
748
Liberty Hill, SC
I have also seen other Korean windshields in m37s, mine just doesn't seen to fit the same for some reason. The difference in hinge measurement is the only thing I have found to explain it.
