CA_LEO
- 5
- 8
- Grass Valley, CA
So, I’ve tried searching this forum and countless others. I’m looking for the 5/16 shouldered studs that mount onto the nose of the water pump and keep the fan pulley centered and attached to the water pump. I found a part number in the 289-34P TM, which was 14061661. Problem is this is listed as a metric bolt thread, and the TM says I need two, whereas mine has four. I’m super confused about this.
I’ve searched everywhere I can think of and can’t find any studs that are the same size. Does anyone know if my studs are just odd, or if there is another part number or source to get these?
I should also note, the ones from LMC do not have the flanged shoulder like mine have. Below is a picture of the only one of these studs I was able to get out of the original water pump semi undamaged.
Thanks for any help you can give
