6.2 engine question
SteelNinja
174
Hills of / TN
I have a dumb question- what is the knocking noise in the 6.2 diesels ? It sounds like a rod or broken flywheel... Yet Ive heard a lot of these engines have a knocking noise . Mine only has 26K miles ..
WillWagner
3,197
Monrovia, Ca.
Most of the time, it is the "squeeze and bang" that makes noise in a diesel. They are fired by compression and not spark. Listen to a Cummins ISB with the VP44 pump
LT67
516
Bowdon, GA
If an old school indirect injection non turbo diesel is quiet while running, then something is wrong😂
Seriously, a video of the noise you are referring to would help.
SteelNinja
174
Hills of / TN
I appreciate all the help, Im not tech savvy - so I don't know how to record and paste it to the site( here) ..
I hope all it ok with it , Im made a bank note - Id be up the creek if it has a bad issue....
Keith_J
1,328
Schertz TX
Cold weather will make more noise when the engine is cold. Air is denser and injection timing is advanced. Check for proper warm up that there is no voltage on the green wires to the injection pump. This also actuated high idle speed.
Idle noise is the greatest since injection is very short so it burns quickly. More throttle means longer burn time and less noise .
SteelNinja
174
Hills of / TN
I found this video on youtube ( mine sounds louder) but.....
at the 2:30- 2:45 min. part .. Its like a clacking/ slapping sound
LT67
516
Bowdon, GA
That's the normal diesel rattle in cold weather. My 85 M1008 sounds just like it
Btw, the ratting sound of a 6.2 diesel on a cold start is a thing of beauty... it's music to my ears.
2INSANE
856
Belgrade, Montana
Sounds great to me! Any slapping noise could be your V belt being loose and slapping on your upper radiator hose shield. Open hood and check for play in the belts.
Rutjes
272
Amersfoort, The Netherlands
I agree with the posts above. But, check your harmonic balancer. Just to be sure...
I don't want to scare you, but my friend recently bought a M1008 and after a couple of weeks it started making a rattling/ticking noise. From certain angles it was really loud. We finally found the damper and waterpump where the cause. The waterpump was fairly recently replaced by the previous owner, but it didn't have an indent on it on the bottom, right above the damper like most have. Must've been some cheap chinese cast. The balancer must have gotten out of round and was hitting that part of the waterpump.
