Thermal board
Beanerboy
Fort Irwin
After seeing those photos I think "just to be safe" you need to totally scrap that CUCV. There is just no repairing that thermal board.
I wish I could trash the damn truck but it is still company property. I have to retract the statement of not reusing that board. After some hard thinking and what if possibilities I came to a conclusion. As you can see, I bolted together the wires in the left side (facing the vehicle), the side that I had to break off. One wire had a piece that connected to both bolts at the same time. I bolt together that end with the other wires and then the stud that was still good on the board I reconnected the wires to it and remounted the board. The vehicle is running and completely operational. It is still cracked where the I broke out the stud but it will keep the wires from arching out on the fire wall.
48cj2a
34
Central, IL
Never understood why GM used that two stud terminal block even on the Civilian trucks.
Gm cars of that era don't have them
Beanerboy
Fort Irwin
Not sure either, but whatever! I worked with what I had. If I didn’t have those pieces I would just put two bolts that fit the wiring eyelets and electrical tape them so they wouldn’t arch out on the firewall.
