Crazyguyla
- 124
- 43
- Altus, OK
Can the intank pump be used in gasoline to prime a gasser motor??
He doesn't have a multi fuel engine. He has a gasoline, carb engine. "gasser motor".Since the multifuel engine can run on gasoline, by design, yes. BUT I wouldn't trust an ancient electric motor inside my gas tank.
To me his question was: If I submerge an electric pump usually used for DIESEL in a GASOLINE tank, will I blow myself up?Either I, or both of you miss read his question. He has a Gasser Truck, with a Gas engine, and wants to use a Deuce internal tank Fuel Pump to prime/run the Carburated Gas engine, instead of the mechanical Gas engine fuel pump mounted on the block, or as a booster to it.
prime it until the carb is full, then its primed. Carbs dont like high pressure fuel. you may force gas past the float/s and into the intake. But I guess since most trucks have a fire extinguisher, you'll be fine.The reason I asked if the MF pump can be used for gas, my fuel tank has pin holes along the top and side. It's repairable now, but might have more problems once all the trash is cleaned out. I have a fairly new MF tank, MF pump bracket, and electric pump assembly from an M109 SPFA fuel tank. I want use the MF tank and pump to prime the gas engine, but turn it off after the engine starts. Hand priming a gasser after it sits awhile is a pita.
