Anyone repair / replace spare tire nylon webbing?
Reworked LMTV
1,125
TN
Anyone repair / replace spare tire nylon webbing? Mine is worn. Thought about getting some webbing, but I don't sew : )
ckouba
1,590
Oregon
Mine may be available. Ditched the OEM system for my camper project, it's yours for the having but gave some other stuff away earlier so need to check if I still have it. Can check in the next day or so.
Reworked LMTV
1,125
TN
Awesome! Thank you!!
Third From Texas
6,327
Corpus Christi Texas
fyi:
Any local sewing shop can likely handle making/repairing webbing, but certainly any canvas shade or sail shop.
Keep in mind that the older stuff can get pretty stiff, so as far as repairs go ymmv.
All that is really needed a heavy duty sewing machine with a heavy-duty needle.
The trick to cutting it clean is to use a *really* hot blade (and don't pull on the webbing, just enough pressure to keep it tight). Again, a sailing or canvas place will also have a tool for clean cutting as well, but I always used a blade.
Nothing wrong with a used takeoff, though. As long as it's not be dipped "surplus gold" and sold for $500....
ckouba
1,590
Oregon
@Reworked LMTV - You're first in line if you want the one from my rig. Otherwise it looks like at least 2 other people are on the hunt for one and I'd be happy to pass it along if you're pursuing an alternate option.
ckouba
1,590
Oregon
PM me your address and I will get it your direction in the next day or two.
