All ready did its discountCheck the remote air brake controller on the rear deck of the wrecker
it may be engaged or partially engaged
to be safe- you can dump the air out of the system - if it is possible the pancake it is out of adjustment. I have had air out that seems to be working ok. Just peddle is sloppy with lots of play. I going to put new return spring on. Old one i can pull apart by hand.
