ckid
- 89
- 18
- Waynesville, NC
I've searched the surplus sites, and tried searching here and google with no luck.
I'm replacing the wiring harness in the deuce. When unplugging the dash gauges, I found most of the rubber boots on the back are dry rotted and crumbling away. The gauges themselves are good, so I don't really want to spend $400 on replacements. Can you change out just the rubber boots on the back- the female side of the electrical connection? They aren't made the same as the female Packard connectors on the wiring itself.
Same with the rubber piece on my fuel pump. The pump is good, but the rubber connector is drying out (the piece on the pump itself, not on the wire that plugs to it.)
If there are replacements out there, I haven't seen them so would appreciate a point in the right direction. Thanks!
