- 1,117
- 1,051
- Perry, FL
What are folks using to secure AR-15 type weapons in 5 tons?
Thank you. Found only one on eBay. They're like hens teeth these days.Hi Russ,
I recently saw a thread on that. https://www.steelsoldiers.com/threads/seeking-cab-rifle-mount-part.202288/
Also saw references to ePay and Eastern Equipment.
.Thank you. Found only one on eBay. They're like hens teeth these days.
That's the kit for an M35 or M809 cab, but it has all the parts you would need to attach the 2 passenger mounts. In an M35 cab, it uses the L bracket to hold them both near the center of the cab. The M939 mounts them both to the flat surface of the dash and doesn't use that bracket. The M939 also mounts a third one to the inside of the driver's door, which you don't have parts for in the kit you bought.I ordered this one. Will it work?
Thank you sir! If I can't figure it out, I'll hit you up.That's the kit for an M35 or M809 cab, but it has all the parts you would need to attach the 2 passenger mounts. In an M35 cab, it uses the L bracket to hold them both near the center of the cab. The M939 mounts them both to the flat surface of the dash and doesn't use that bracket. The M939 also mounts a third one to the inside of the driver's door, which you don't have parts for in the kit you bought.
As with many things on these trucks, I'm sure you could do it your own way or make the L bracket work in your M925A2 if you were so inclined.
I'm attaching a couple pictures I took of the instructions that came with my M939 kit that show where the two passenger side mounts 'officially' go, if you want to go that route. I'm not sure if they will attach with good enough resolution for you to see the measurements. If not, send me your email address by PM and I can send you the higher resolution version. It's still a copy of a copy and very grainy but it was good enough for me to read.
Thank you Charles. Regarding the parts, I've been stuck at the store all week due to an employee being out and haven't been able to get to the bank yet.Iv got a mount out of a ch-47 for the cockpit. Its made for an m4, but i was able to fit my ar in it, even though it was a very tight fit. Ill see about getting some pics of it, if i can find it tomorrow. My plan was to take my center seat/console out of my ram p/u and mount it on the floor, along with fabbing up a mount for my shotgun, and install some ammo cans for storage and extra mags.
The base will be easy to lengthen and build more, but the latch system, will require some extra time, and for a cleanerlook, machining, but it could be done with patience and basic power tools and files.
