tbeson
- 13
- 8
- South Carolina
Help, again! I have looked locally at older model 1992 HMMWV with no luck being able to figure out where the wires come from to connect the speed sensor or temp sending unit, as they do not have or are missing the same things I am missing.
I have a 1998 M1123 HMMWV missing the connection from the speed sensor and no wires to the temp sending unit.
I have been looking over the forum for any photos of the wiring harness on the Capt.'s side (VGG) drivers side upper wiring harness that supplies the 4 glow plugs and returns to the transmission. I have two final wiring connections I can't seen to figure out from the TM. I'm a picture kind of guy, so any photos of this area would be greatly appreciated. I am making the assumption the temp sensor and speed sensor should be somewhere in that bundle. Thanks in advance as you guys have been able to figure out these before the sun goes down.
