Ezduzit
- 10
- 3
- NW Indiana
Checking more into the option of using the m812 bridge truck I found for sale locally.
The price is very attractive but the over width issue turns out is not so simple. My research has resulted in conflicting information on how these over the legal limit for road use bridge trucks gained their extra width. It may be that they used more than one method over the years?
First the bed and boom could be removed to take away the outer most extreme part of the trucks width problem of between 11-13 ft depending on which model? This still leaves the dual 14 20s still in DOT violation at where most say measures at 9'6".
So we still need to slim down somewhere close a foot and a half by either:
removing the outer dual wheels,
removing spacers,
changing to a different offset set of wheels,
flipping the hubs or any combination of some or all of these modifications.
It has even been suggested the only way is to swap the entire rear bogie from a truck with standard width axles.
As for axle housings dimensions. Some say it is the same as all other 5 ton housing's and uses 3" spacers on the hubs. Others report housing to be 6" wider with 1 1/2" spacers on the hub to give it a total of 9" over what I will call standard width. Most seem to be in agreement of 3" spacers on the front hubs to keep the deep offset wheels from interference with front suspension parts.
So what can I take away from all this digging? It must be possible. After all I did find a picture of at least 1 m812 bridge truck that had gotten skinny. Not sure if it was enough to be legal. Could be you just have to buy the truck, tear into it and find your solution.
For me it is the extra long wheelbase, winch and the fact the truck can be bought reasonably priced local that has me leaning this way.
Another option would be the dump that is also available from this same location that is already at a legal width. I would need to lengthen the wheelbase on this truck.
This could be easier and cheaper than narrowing the bridge truck? Either truck would be getting singles so a wheel change would likely be needed on both.
As for capacity the bridge truck may be built heavier. Axle housing springs double frame are some of the things that have come up. I will do some digging on the dump truck next. I don't know the model number on it yet. I would think both trucks could handle a bus body
turned RV down some rough forrest access roads.
removing spacers,
