- 1,339
- 1,912
- Las Vegas Nevada
I have zero experience with the Hmmwv rim but I will tell you I think it’s a bad idea. 16.5 wheels have the least pronounced bead grove of all the wheels that I have personally seen. You don’t deflate so you might be ok. Very least I would personally do the pvc pipe. I’m a big fan of the rubber things that everyone throws awayFinally got the spare tire opened up. It has magnesium runflats. (I though the Army and possibly other military branches discontinued the magnesium type!!???)
Is it possible to remove the run-flats and reinflate the tires -or- are double bead-locks required. I never de-flate the tires to less than 20 psi.
Thanks in advance for your advice.
