Hi all, had a problem with the right rear and left front blinkers not working. 1st checked bulbs ok. Both brake lights worked so that told me grounds and wires were ok for the rr blinker inop. After checking a few more things i took blinker switch apart and found two contacts corroded, just happened to be for the lf and rr blinkers. Cleaned all contacts with emery cloth and re assembled. Turned on rr blinker and ran to rear of truck to complete disappointment, nothing.. haha- forgot to toun on service switch. That took care of my problem. Hope this helps someone else..
