So I Jump in the Truck and No Power to WTEC3
Third From Texas
6,669
Corpus Christi Texas
I'm surfing the TM as best I can do with my phone. Truck starts just fine, but no power to the controller.
Trying to find which relay to check but it's 180 degrees in this cab. LOL
I'll also pull the dash and inspect for lose wire,
Third From Texas
6,669
for others future reference......
which ground was the culprit?
Rule of thumb, when something fails go back to the last thing you screwed with before bothering with the TM. I pulled the 6K generator off the truck to redo some stuff. When I disconnected my leads I had run to the 12v gen starter I inadvertently disconnected the small OEM lead coming off the ground side of the 12v battery. Seems the transmission wants that juice.
LOL
chucky
19,294
TN .
My truck did that just one time when i first got it and when i grabed and wiggled the wiring harnass going to the trans controller cha ching it lite up and never did it again like maybe a slight pin crustyness fixed with a good shake
