Disassembly done and wiped down. Did a quick visual and see a lot of what I call questionable. I'll break this down with the pics.
As previously noted pretty dry compared to the video and the inner bearing looks hot.. Some kind of green grease.
Damage on spindle. One pic shows a ding in the shaft. As well as scratches. Still can't get the inner bearing off. Does this have to be driven out from the back side?
Little grease on the knuckle.
U-joint grease caps are loose on some.
The thrust washer on the inboard side of the knuckle as well as the mating surface of the seal retainer are all chewed up.
View attachment 844518View attachment 844519
Knuckle shaft pitted either through casting or repaired corrosion. Suspect casting.
Part of the knuckle appears to have been dragging on the inside of the axle housing as well as the lower king pin boss.
View attachment 844521View attachment 844522
Upper king pin has some scoring and a small amount of slop with the busing. Lower is better but still a tiny bit.
Sorry for the length of this post but I'm still cleaning and researching.
I worked on jet aircraft for 40 years so I tend to treat everything like the smallest blemish could kill everyone. I'm trying to remember IT'S NOT AN AIRPLANE!
So am I splitting hairs here?
