Last month I towed home a 1008...it didn't have batteries or a key...I replaced the batteries with brand new 6t's and replaced the interlock...it wouldn't turn over...I do all kinds of usual testing then head underneath only to find there is no starter!! I was extremely lucky that the battery cable was at a place not touching anything...it has the full 24 volts! Anyhow, with all the looking before I almost started a fire was I couldn't find the starter relay...I think I found the plug as it does react to the start position on one of the wires...My problem is sourcing the right starter now as most catalogs don't list a 24 volt starter only 12 volt...same goes for the relay...side note, this does have a new harness under the dash...kind of a bonus but does make me think the original burned up if the relay melted on hence why the starter is gone and the relay. Any advice on sourcing these 2 parts would be great!![20210913_114511.jpg 20210913_114511.jpg](https://www.steelsoldiers.com/data/attachments/600/600361-03ab51119f342b8ed13a556dd327ebce.jpg)
![20210913_131004.jpg 20210913_131004.jpg](https://www.steelsoldiers.com/data/attachments/600/600362-7d27a9bec886cfadae9e5e0998fce205.jpg)
![20210913_131033.jpg 20210913_131033.jpg](https://www.steelsoldiers.com/data/attachments/600/600363-da681732535319cea17d03f81edb1eaf.jpg)
![20210913_140226.jpg 20210913_140226.jpg](https://www.steelsoldiers.com/data/attachments/600/600364-40e4900c2efe1078480e5a2a59f749ae.jpg)
