- 413
- 891
- 93
- Daytona, FL
Trying to install a bed light using the Warning light switch but cannot locate the cable location..any hints ?
does it exit anywhere from the dash area to the back of the cab ?On the back of the cab.
"Amber flashing/warning light" that is controlled by the switch located between the master on and hazard switch..
Your lights are in service drive though, right?unfortunately there is no power to the wires when master switch is on and I hit the Convoy light switch....fuse and relay are in place...ugh. electrical Gremlins ..again..
no sir...brake/turn signal mode..makes a difference?..Your lights are in service drive though, right?
You're testing this with the service (headlights) "on", correct? I don't have access to my files still, but I sort of recall that my convoy light only worked with ark or service lights active.unfortunately there is no power to the wires when master switch is on and I hit the Convoy light switch....fuse and relay are in place...ugh. electrical Gremlins ..again..
