ever notice that...
coachgeo
3,484
North of Cincy OH
might be something left out of text......but IMHO more likely it might be just a cut & paste of the top knob (cab tilt at raise) being pasted to all the knob positions below it by the illustrator.
being in a profession where using illustrations is common.... it was oft stated..... "TEXT is correct; not illustrations"
Ronmar
8,182
Port angeles wa
where are the LMTV Mad Scientists when you need them ?.... paging Suprman, Ronmar, Awesomeness.....lol
What do the instructions inside the valve door say? Those from the manufacturer should trump any manual….
From a hydraulics standpoint, the valve position of valves on circuits that are not selected should be irrelevant if the function selector valve is working properly and isolating the flow to one circuit at a time…
Awesomeness
1,521
Orlando, FL
Here's a picture of mine, for what it's worth. As others said, they don't need to all be switched to the lower position. These manuals were illustrated in the '90s, before CAD and 3D graphics could have helped make it an easier task. They probably drew the pictures once each, all down, and all up, so that they could cleverly reuse them in all the places in the manual that referenced the position of one of the valves.
