BERZERKER888
- 896
- 93
- Daytona, FL
Pretty sure BAE was able to find worse for less.When S&S was specing out all the rubber parts on FMTVs, they checked the “crappiest possible quality” box.
Lowest bidder baby!When S&S was specing out all the rubber parts on FMTVs, they checked the “crappiest possible quality” box.
I've noticed that all the A1 trucks' rubber have been significantly worse than the A0 (not that it's giving much credit to them).Pretty sure BAE was able to find worse for less.
My 2008 has worst rubber in it than my 1998.
the problem I ran I to was no one makes just the diaphram let alone the entire PPV..sure Haldex makes a PPV that you need to "engineer" to make it fit... I lucked outEveryone should have a spare one in their parts anyway. Winter isn't here and they tend to freeze up very badly since they are next to the wet tank. Freezing up cracks the rubber and that is that. This is why the military went to silicone wheel o rings.
PPVs are all the same. It only depends on the fitting sizes you need and it's style. Some are adjustable, some aren'tthe problem I ran I to was no one makes just the diaphram let alone the entire PPV..sure Haldex makes a PPV that you need to "engineer" to make it fit... I lucked out
thanks is everyone !
