What the heck is it
Rrent
142
Texas
Considering the cut wires on either side - I’m guessing it had something to do with the radio.
Yes, that metal thing behind the air cleaner. And yes (again) I know these wires need attention…BA7E5A12-7791-4959-8603-2A8FB47F7F53.jpegFF25692B-FD0E-46E4-837F-8EC078FEE330.jpeg
WWRD99
1,835
York Pa
Yes, that metal thing behind the air cleaner. And yes (again) I know these wires need attention…View attachment 850844View attachment 850845
That's the 24 volt to 12 volt converter...if it's not hooked up then it's no big deal...it knocks 24 volt to 12 volt...I have one in the truck but the blazer one was removed long ago.
cucvrus
10,467
Jonestown Pennsylvania
In my opinion. I would hook it up. I ran these trucks for 27 + years with no adverse conditions or issues. It also helps pull the glow plug voltage from both batteries during cold start and reduces the strain and alternator on the front 12 volt battery and the Gen 1. I bought everyone I ever seen for sale because I read so much that they failed. Now I have a stack of complete resistors and after several hundred thousand miles and 100+ CUCV's I never had one fail. I had one get hot but that was a mouse nest on the back side. It smoked and burnt slightly and continued to operate as designed for years after. Do as you wish. But please repair that fusible link that is running to the 12 volt power point. Have a Great Day.
Rrent
142
Texas
Once I remove the metal “plate/cover”. Will the repair be self evident? Is the fusible link anything special/different?
SomeNewGuy
95
VA
cucvrus
10,467
If you look closely you can see on the drivers side where someone cut the 10 gauge wire coming out of the resistors. I would remove the resistors and replace the wire and reattach it to the top post of the glow plug relay. The fusible link I am referring to is the poorly crimped yellow eye end that is on the main 12 volt power point connection. But I am being honest I never had any issues with any stock electrical configurations on a CUCV. Did I have things fail? Yes I would be a liar if I said differently. I just looked where the issue was that caused the failure and fixed that issue. I work on lots of cobbled up stuff and always repair hack jobs whenever possible. As many times as the TM's are referred to on this site I can't image the advise of hacking the systems. The originals worked for years and are about as simple as can be. Do as you wish. I like nice clean original vehicles. Good Luck. I still use the A C Delco 13G glow plugs and always will.
Rrent
142
Texas
I’m pretty sure a 10 gauge as also cut from the passenger side.
Is the fusible link anything special? If not, I’m guessing there is a size associated with it?
MarcusOReallyus
819
Virginia
Look up the "Helpful Threads" sticky at the top of the forum. Scroll down and you'll find a couple of threads which tell you how to remove it. Just reverse the steps.
Or not....
The circuit is simpler without it. It drops the 24v down to 12v which is then fed to the GPs. This confuses a lot of people, as you only see the drop when the GPs are actually operating. So, a lot of people remove it. It's not a trouble spot, though. It's really hard to burn out those resistors. It has been known to happen, but not often.
It works either way. /shrug/
Rrent
142
Texas
Looks like 24 volt on the passenger side and 12 volt to the gp solenoid on the driver’s. Fusible links?
Rrent
142
Texas
Or not....
Looks like 24v on the passenger side and 12v to the gp solenoid?
MarcusOReallyus
819
Virginia
Hey, since you are new to CUCVs, I'd say leave it alone unless things aren't working. Get to know the beast, fix any actual problems you have (this ain't one), and later you can decide if you want to mess with it.
It's no big deal either way.
MarcusOReallyus
819
Virginia
Yes, sort of. If you have the stock setup, and your GPs are NOT engaged (turned on), you will see 24v all the way to the top of the GP resistor. When the GPs are engaged, you'll see 12v on the driver side if everything is working correctly.
If any of your GPs are fried, you'll see somewhere between 24v and 12v on the driver's side, depending on how many resistors are fried.
With the resistor bypassed, it's 12v all the way across whether your GPs are good nor not.
Please read the sticky on how it works before you decide to "fix" this.
Rrent
142
Texas
I hear that - it will definitely be somewhere down on my to-do list. Looks like parasitic battery drain might well have shot to the top of that list - but, that’s a tomorrow thing,
