What were the good voltages?I tested both alternators - good voltage at idle. After the 40 mile trip, I did start it (to be sure it would), but turned it off almost immediately. Might the, hot, starter (if not at 100%) have sucked the batteries down? Is there anyway for the starter to cause/contribute to the drawn down when the vehicle is not running?
I just tested with my Harbor Freight battery load tester. The #1 was rebuilt 3-4 months ago, #2 rebuilt 2-3 days ago. The number one seems to move the needle after the truck has been running for a while. Hopefully unrelated (but I didn’t think to notice the timing), I did get the high idle/ip timing advance set up and can tell when the truck warms up enough for it to “kick-off”.What were the good voltages?
I was looking at that exact one - kinda pricey for my “truck budget”, but I’ll probable get it. Have you had a chance to hook yours up? I would love a real world review before I spend the $’s.Just got one of those. My bro had the hook up to get one cheap.
that thing isI've got a 24v system in my Bass Boat, and I have a Genius Batter Charger that charges all 3 batteries (starting battery and 24V (two 12s) trolling batteries) on a trickle charge. Probably one of the best purchases I made for that system, because those batteries aren't cheap., and that Genius battery charger can bring some batteries back from the dead.
I may do the same thing on this truck if I'm going to be letting it sit for long periods.
I paid 170 on Amazon. Not sure why someone would charge (or pay) double.that thing is
Fully submersible.
and is 300 bucks.
NOCO Genius GEN10X3 12V 30A 3-Bank Onboard Marine Battery Charger Maintainer – For Boats, Jet Skis, & Pontoons – Lead-Acid & Lithium Batteries
The NOCO Genius GEN10X3 is a compact and powerful 12V 30A 3-Bank onboard marine battery charger and maintainer. The GEN10X3 is designed to safely support 12-volt lead-acid and lithium-ion batteries of multiple chemistries such as flooded, gel, maintenance-free and AGM batteries, as well as...no.co
I haven't had a chance to hook it up yet. I'll give a review once I've had a chance to use it.I was looking at that exact one - kinda pricey for my “truck budget”, but I’ll probable get it. Have you had a chance to hook yours up? I would love a real world review before I spend the $’s.
Alternator #2 is 14.8 which is the regulator set point so it's ok. Alternator #1 is 13.8 and that is low. If the battery is ok and just discharged it should eventually come up to about 14.8. If it doesn't come up to 14.8 or within a couple of tenth's of a volt about 5 minutes after starting the engine, I would charge the battery over night and then load test it. If the battery is ok then there's a problem in the alternator or truck wiring.I just tested with my Harbor Freight battery load tester. The #1 was rebuilt 3-4 months ago, #2 rebuilt 2-3 days ago. The number one seems to move the needle after the truck has been running for a while. Hopefully unrelated (but I didn’t think to notice the timing), I did get the high idle/ip timing advance set up and can tell when the truck warms up enough for it to “kick-off”.View attachment 851530View attachment 851531
It does increase with run time - I’ll keep checking. Fingers crossed it’s not wiring.Alternator #2 is 14.8 which is the regulator set point so it's ok. Alternator #1 is 13.8 and that is low. If the battery is ok and just discharged it should eventually come up to about 14.8. If it doesn't come up to 14.8 or within a couple of tenth's of a volt about 5 minutes after starting the engine, I would charge the battery over night and then load test it. If the battery is ok then there's a problem in the alternator or truck wiring.
