Another M1010 owner
Sharecropper
1,077
Paris KY
Found a little massaging was needed for clearance. While the Sherpa Steed 17K winch does fit between the frame rails, when centered the motor needs some more room for clearance. Admittedly the motor on mine looks different than pictured on their web site. Also got the control box mounted and starting to run wires. 🇺🇸🇺🇸🥓🥓🥃🥃 #m1010 #cucv
Just curious - are you powering the 24v winch with the 24v slave wiring?
Mad Texan
1,151
Chester County, PA
Wrestled everything back together! Certainly happy to use new hardware for the bumper, much easier to get started. Added anti-seize on all the threads. Hooked up 24v from the buss bars, and it’s running! 👍 The @factor55 XXL looks beefy on there till you step back. 🎄🌲🎄🇺🇸🇺🇸🥓🥓🥃🥃 #m1010 #cucv
Sharecropper
1,077
Paris KY
I'm hooked. I want to order the same outfit from Sherpa. Would you be so kind to share your ordering information? Dayum that is good looking.
Mad Texan
1,151
Chester County, PA
Sharecropper,
I ordered directly from Sherpa 4x4 and actually I'm not sure where else to get one. I ordered the Sherpa Steed 17K 24v with 92' rope ($1049) and extended battery cables ($99). The 148' version changes the winch body and it will not fit in the winch plate from Engineered Vintage . I went with the 17K because of the GVW of the M1010 (9450lbs) and following the rule of 1.5xGVW had me closer to 15K. If I had a M1008 I probably would have done the Sherpa Colt 12K but the price difference is only $50. The Colt does have a faster line speed because of internal gearing.
Additionally, I ordered the Wireless Remote Kit ($119) afterwards...
I also purchased addition hardware for my installation, the kit comes with most but I changed some of it around.
Sharecropper
1,077
Paris KY
Sharecropper,
I ordered directly from Sherpa 4x4 and actually I'm not sure where else to get one. I ordered the Sherpa Steed 17K 24v with 92' rope ($1049) and extended battery cables ($99). The 148' version changes the winch body and it will not fit in the winch plate from . I went with the 17K because of the GVW of the M1010 (9450lbs) and following the rule of 1.5xGVW had me closer to 15K. If I had a M1008 I probably would have done the Sherpa Colt 12K but the price difference is only $50. The Colt does have a faster line speed because of internal gearing.
Thank you for that information. I had been looking at Sherpa for quite some time, and really liked their product. I guess it took your post to flip my switch. I know all about ordering from Australia. I purchased my supercharger from Bullet in Yatala Qld, wherever the hail that is.
I'll get my Sherpa Steed ordered right away. Again, thanks for a most informative post.
Mad Texan
1,151
Chester County, PA
No problem! My only issue with Sherpa was they notified me 5 days after ordering of the back order on the winch. Then it was the 2 weeks, any day emails, which is becoming the norm these days.
Sharecropper
1,077
Paris KY
Sharecropper,
I'm on Sherpa's website now preparing my order. I plan to order the same unit as you did. Question - did you order the 500 amp fuse & fuse-holder?
Mad Texan
1,151
Chester County, PA
I did not order the 500 amp fuse/ holder from them. I'm using a Blue Sea Systems terminal with a 250a fuse. With the 24v application the winch is supposed to pull a max of 225a so I feel the 500 is a little overkill. They fit the bussbar nicely...
Sharecropper
1,077
Paris KY
Thanks. I plan to add two Blue Sea terminal blocks anyway to power all my stuff (one for 12-volt and another for 24-volt), so I will simply add one of the same fuses to my order. I will appreciate it if you will provide the Blue Sea part number. Never mind, I clicked on the link in your post above.
Another question - is there a specific kit number for the Engineered Vintage winch mount? I was on their website last night preparing to order it but the installation directions indicated that their kit would not accommodate the Sherpa Steed 17,000. Maybe they hadn't updated their documentation yet?
Thanks again for all your help.
Mad Texan
1,151
Chester County, PA
There is only one kit from Engineered Vintage for our trucks. Interestingly enough if you look at the Winch Dimension from Sherpa for the Colt 12k and Steed 17k with the 28m spool they are the same dimensions. But, the Steed with the 45m spool in definitely bigger like the Stallion 25k. Because of the same model having two different dimensions, Ben, at Engineered Vintage may not update as it may confuse some. The bigger body winch will not fit in the winch mounting tray from Engineered Vintage as it's not wide enough.
What I haven't measured on mine is the distance from the winch mounting hole to the end of the motor. On the dimension sheet it says 7 3/8" but the terminals are different on my winch (as shown) and there is a heat sink on the end of it. This is where I had a clearance issue as I couldn't push the winch over far enough to clear the frame. So I cut the bottom of the frame rail for some for clearance, not a lot as you can see what I cut off. I'm not sure that there wouldn't be the same issue with the Colt 12k at this point or not.
I'll see if I can measure it today and can let you know...
Sharecropper
1,077
Paris KY
Thank you. The Sherpa Steed is on its way, and I just hung up with Ben at Engineered Vintage and got the BBWM ordered. Next in line is Blue Sea. Now I just need to find the time to get everything done!
Mad Texan
1,151
Chester County, PA
I understand what you're saying. I spent an hour yesterday at the truck going through old lists, making new a list. Then walked around the truck finding more to add to the list of things to get done. I ended up with almost a page of things to do... :ROFLMAO:.
20,529
Two years of working on my first project truck and the list is finally getting shorter.
When I started, every time I fixed something on the list - six, or eight, or ten more things were ADDED to the fix list.
Mad Texan
1,151
Chester County, PA
I measured from the mounting bolt to the end of the heat sink and came up with 7 7/8" as compared to dimensional drawing saying 7 3/8". So mine came in 1/2" longer which necessitated my trimming of the frame. I think it would have a cleared if it was the shorter measurement or just required a little grinding. I could have taken some more out but I don't think it's going anywhere.
2INSANE
847
Belgrade, Montana
Jesus! That Sherpa winch is a great deal! I paid $2800 for my Warn 24v winch about 8 years ago and it is only rated 12k. Nice score! Have you thought about winching up a big tree or a 100% vertical incline just to see if it would lift it? Would be cool. I’ve thought about doing that for fun. Now that you have a winch, all your buddies will be asking you to pull them out and you will never get to use it for your actual truck because everyone will get stuck before you do! Lol!
Also you should charge a hook up fee and pull fee and eventually you will have enough money for a couple more upgrades! 😂
Mad Texan
1,151
Chester County, PA
I own a couple of Warn winches but never a new one, to much $$$. I'm hoping the Sherpa works out well and the reviews are good. I do have a 8274 waiting for a Willys project that hopefully happens some day.
I think it was Hickey that use to pick up a truck and hang it in their ads. :LOL: Not sure if I want 10K swinging in the air from a winch line...
