- 657
- 1,151
- 93
- Chester County, PA
Found a little massaging was needed for clearance. While the Sherpa Steed 17K winch does fit between the frame rails, when centered the motor needs some more room for clearance. Admittedly the motor on mine looks different than pictured on their web site. Also got the control box mounted and starting to run wires.#m1010 #cucv
I ordered the extended battery cables (10') when I ordered the winch so my wiring for the slave is still intact.Just curious - are you powering the 24v winch with the 24v slave wiring?
Sharecropper,I'm hooked. I want to order the same outfit from Sherpa. Would you be so kind to share your ordering information? Dayum that is good looking.
Thank you for that information. I had been looking at Sherpa for quite some time, and really liked their product. I guess it took your post to flip my switch. I know all about ordering from Australia. I purchased my supercharger from Bullet in Yatala Qld, wherever the hail that is.Sharecropper,
I ordered directly from Sherpa 4x4 and actually I'm not sure where else to get one. I ordered the Sherpa Steed 17K 24v with 92' rope ($1049) and extended battery cables ($99). The 148' version changes the winch body and it will not fit in the winch plate from . I went with the 17K because of the GVW of the M1010 (9450lbs) and following the rule of 1.5xGVW had me closer to 15K. If I had a M1008 I probably would have done the Sherpa Colt 12K but the price difference is only $50. The Colt does have a faster line speed because of internal gearing.
Additionally, I ordered the Wireless Remote Kit ($119) afterwards...
I also purchased addition hardware for my installation, the kit comes with most but I changed some of it around.
No problem! My only issue with Sherpa was they notified me 5 days after ordering of the back order on the winch. Then it was the 2 weeks, any day emails, which is becoming the norm these days.Thank you for that information. I had been looking at Sherpa for quite some time, and really liked their product. I guess it took your post to flip my switch. I know all about ordering from Australia. I purchased my supercharger from Bullet in Yatala Qld, wherever the hail that is.
I'll get my Sherpa Steed ordered right away. Again, thanks for a most informative post.
Sharecropper,
I ordered directly from Sherpa 4x4 and actually I'm not sure where else to get one. I ordered the Sherpa Steed 17K 24v with 92' rope ($1049) and extended battery cables ($99). The 148' version changes the winch body and it will not fit in the winch plate from Engineered Vintage . I went with the 17K because of the GVW of the M1010 (9450lbs) and following the rule of 1.5xGVW had me closer to 15K. If I had a M1008 I probably would have done the Sherpa Colt 12K but the price difference is only $50. The Colt does have a faster line speed because of internal gearing.
I did not order the 500 amp fuse/ holder from them. I'm using a Blue Sea Systems terminal with a 250a fuse. With the 24v application the winch is supposed to pull a max of 225a so I feel the 500 is a little overkill. They fit the bussbar nicely...I'm on Sherpa's website now preparing my order. I plan to order the same unit as you did. Question - did you order the 500 amp fuse & fuse-holder?
There is only one kit from Engineered Vintage for our trucks. Interestingly enough if you look at the Winch Dimension from Sherpa for the Colt 12k and Steed 17k with the 28m spool they are the same dimensions. But, the Steed with the 45m spool in definitely bigger like the Stallion 25k. Because of the same model having two different dimensions, Ben, at Engineered Vintage may not update as it may confuse some. The bigger body winch will not fit in the winch mounting tray from Engineered Vintage as it's not wide enough.Another question - is there a specific kit number for the Engineered Vintage winch mount? I was on their website last night preparing to order it but the installation directions indicated that their kit would not accommodate the Sherpa Steed 17,000. Maybe they hadn't updated their documentation yet?
Thanks again for all your help.
I understand what you're saying. I spent an hour yesterday at the truck going through old lists, making new a list. Then walked around the truck finding more to add to the list of things to get done. I ended up with almost a page of things to do...Thank you. The Sherpa Steed is on its way, and I just hung up with Ben at Engineered Vintage and got the BBWM ordered. Next in line is Blue Sea. Now I just need to find the time to get everything done!
.I understand what you're saying. I spent an hour yesterday at the truck going through old lists, making new a list. Then walked around the truck finding more to add to the list of things to get done. I ended up with almost a page of things to do....
Ha. You are lucky. I've been working on my M1028 since 2010 and my list keeps getting longer..
Two years of working on my first project truck and the list is finally getting shorter.
When I started, every time I fixed something on the list - six, or eight, or ten more things were ADDED to the fix list.
I'm at three and a half years....
I measured from the mounting bolt to the end of the heat sink and came up with 7 7/8" as compared to dimensional drawing saying 7 3/8". So mine came in 1/2" longer which necessitated my trimming of the frame. I think it would have a cleared if it was the shorter measurement or just required a little grinding. I could have taken some more out but I don't think it's going anywhere.Thank you. The Sherpa Steed is on its way, and I just hung up with Ben at Engineered Vintage and got the BBWM ordered. Next in line is Blue Sea. Now I just need to find the time to get everything done!
I own a couple of Warn winches but never a new one, to much $$$. I'm hoping the Sherpa works out well and the reviews are good. I do have a 8274 waiting for a Willys project that hopefully happens some day.Jesus! That Sherpa winch is a great deal! I paid $2800 for my Warn 24v winch about 8 years ago and it is only rated 12k. Nice score! Have you thought about winching up a big tree or a 100% vertical incline just to see if it would lift it? Would be cool. Iโve thought about doing that for fun. Now that you have a winch, all your buddies will be asking you to pull them out and you will never get to use it for your actual truck because everyone will get stuck before you do! Lol!
Also you should charge a hook up fee and pull fee and eventually you will have enough money for a couple more upgrades!![]()
