- 582
- 1,107
- 93
- Cool, CA
I am writing this after dark and will add pictures tomorrow but hoping for some insight/help in the meantime. I decided to replace the glo plug solenoid (old black plastic one) as a precautionary measure as it had not failed yet. I purchased the Napa ST85 and within a few minutes had it changed out. I went to test the glo plugs (key turned to on) to see if we had 12 volts at the plugs. Glo plug light illuminated, but no power to the plugs. Checking at the new solenoid, red wire is constant hot, power from ignition causes both the pink and lt blue to register 12.3 volts, but the circuit out to the glow plugs has no power (orange wires). I tried changing the pink and lt blue wires thinking maybe I had them backwards. Same result. I read here that the ST85 is the proper replacement. What did I do wrong? Do I have a bad solenoid from Napa? I plan on taking the solenoid off and trying to test it. What should I look for? Thanks in advance
