caldreamz
- 29
- 13
- Washington
The vents for the diffs are just hoses. That’s just a capped off fuel line. I suppose it could be a gas tank vent, but the fill tube is so big I wouldn’t think it would need one.Vent for the rear differential?
Seems like a simple process to figure out your problem. Stick your finger where it's leaking and stick it to your nose. You will know right away if it's diesel.I can believe the fuel drain (although I still think its a pretty sketchy way to cap the tube). It was a big leak and if it was differential the tube is above the differential which would indicate pressure to get it up and over and a lot of fluid loss. I'm still not sure why it would suddenly leak but I did recently top off the tank. I will trace it back on Sunday and hopefully answer the question.
