Winch line capacity
Guruman
Not so new member
1,074
Cody, Wyoming
I have a complete winch setup coming (hopefully) off a 5-ton truck. Anyone know what the line capacity is on these? I'm thinking of replacing the aged steel cable with some nice synthetic, probably 1/2". I don't want to order line, only to find out it only fills half the drum.
Also, related, any line recommendations/sources?
ramdough
1,731
Austin, Texas
I thought of doing that, but that would be very expensive. Also, usually synthetic line does not use roller fare leads, not sure why. You could also buy a smaller synthetic line at the same strength and get a much longer line…. But that is also expensive.
If you do pull the trigger…. Please tell us about it….. I am very curious on how that works out.
Guruman
Not so new member
1,074
Cody, Wyoming
Yeah, this info has me looking at a 600 foot spool of 3/8 amsteel. $1800, but it would be epic.
As for the rollers and synthetic... synthetic does fine as long as the rollers are not nicked up. I figure I'll pull the old rollers and touch them up, or turn them down on a lathe and sleeve them with UHMW poly. I also am considering making new aluminum fairleads to replace the two sets of rollers at the front and rear.
If I get real ambitious, I might re-engineer it to a Fores Winch setup, but I won't know if that even feasible until the winch stuff shows up.
Ronmar
8,186
Port angeles wa
I think it would be fairly easy to shift the stock config to a Foers. I am going to install an electric like that, using a fixed shiv at the back in front of the rear fairlead and just pull a loop out and use a donut shiv and a soft shackle at the rear. Having had to move winches front to back a time or two, it will be nice not to have to do anything too fancy to rig for a pull on the opposite end, not even crawling around in the mud to rig the line from front to rear…
Guruman
Not so new member
1,074
Cody, Wyoming
This is exactly what I was thinking, only I was looking into making or modifying a snatch block that could just be un-pinned for use, and re-pinned for storage.
What I'm not sure of is the line routing from one end or the other. getting from the winch to either the front or rear was how it was designed, but the line that returns the whole length would have to get around the winch itself somehow. I have not figured that out yet.
Guruman
Not so new member
1,074
Cody, Wyoming
BTW, I found a seller on Flea Bay. this seems like it might be the way to go. If the drum holds 305 feet of 7/16 steel, then how much 3/8 synthetic would fit? If 500 feet does nto fit, I'd just lop off the extra and splice in a loop on each end for an extender or other rigging.
coachgeo
3,484
North of Cincy OH
I think it would be fairly easy to shift the stock config to a Foers. ...
Gave up on Foers. The complexity and lack of tools and knowledge to engineer myself and too unknown by the avg. good welder/fabricator to make up a Foers installation for me.. Now might change my mind if I can find a way to clone Ronmar and make him a shop slave....
granted also gave up on that cause I got lucky on some 24v 18000 lb warren winches which were over kill for hummers... but with a snatch block likely fine for our trucks. Will mount one fixed on each end and make a slide in mount(s) to put third to assist either end or either side (in a perfect world that is.... aka.... years down the road before any of it gets installed)
