HUMMVEE Oil filter
HAWKMAN
N.E. P.A.
Wanted to check with the HUMMVEE guys if anyone would know if a Baldwin B7042 filter is correct for this vehical......I tried to Google and check online for info but didn't get anywhere. Thanks:-D
jwaller
20
Columbia, SC
Ac pf35
champion lab ph1218
fram hp4
fram ph13
fram ph5
mobil1m1302
motorcraftfl12
purol30040
purol34631
purol35132
wix51060
wix51061
  • Like
Reactions: OBX
mikeyapproved
Sumas, WA.
Hawk, here is the listing I found for that filter: ( I did a Fram cross)
CATERPILLAR
T25D
Peugeot XN1P Eng. [ ]
T40D thru TC60D
Peugeot Gas Eng. [ ]
Peugeot XD3P Diesel Eng. [ ]
XN1P LPG Engine [ ]
TC40D
V25D thru VC40D
Peugeot XD3P Eng. [ ]
V40D thru VC60D
Peugeot XN1P Gas Eng. [ ]
Peugeot XN1P LPG Eng. [ ]
V40D thru VC60D SA
CATERPILLAR-LIFT TRUCKS
T25D
T40D thru TC60D
XN1P LPG Engine [ ]
TC40D
V25D thru VC40D
V40D thru VC60D
V40D thru VC60D SA
DODGE TRUCK
D50
4-2.3L Diesel (9) [1983]
4-2.3L Diesel Turbo (J) [1984]
Power Ram 50
Ram 50
FORD
Escort
4-2.0L Diesel (H) [1987-1984]
EXP
4-2.0L Diesel (H) [1987]
Tempo
FORD TRUCK
Ranger
4-2.2L Diesel (P) [1984-1983]
MAZDA TRUCK
B-2200
4-2.2L Diesel [1984-1982]
MERCURY
Lynx
Topaz
MITSUBISHI TRUCK
Pickup
4-2.3L Diesel Turbo [1984-1983]
NISSAN KIZ
N-450
S-2B25
S-2B30
NISSAN KIZ-EXCAVATORS
N-450
S-2B25
S-2B30
PEUGEOT
505
4-2.3L Diesel Turbo [1986]
4-2.5L Diesel Turbo [1987-1985]
4-2.5L Diesel Turbo CAN [1988-1985]
WESTERBEKE
10BTD
12.5 BTDA
15.0 BTDA
WESTERBEKE (Marine)
15 BTDB
38B Four
W33A
WESTERBEKE-GENERATOR SETS
10BTD
12.5 BTDA
15.0 BTDA
Hope this helps?? You might be able to sell them, but probably not too many here? How many do you have??
Do a search on CAT or Mitsubishi Forklift dealers near you? Might be able to sell them as a package deal?? If that doesn't help, Try Leavitt Machinery in Washington state.....
mikey
PS: I also obtained the specs from Baldwin:
Note the metric thread and specs...
Descriptions: Lube Spin-on Contains: Anti-Drainback Valve
14 PSID By-Pass Valve Fits: Caterpillar Lift Trucks; Citroen Trucks; Peugeot Automotive, Light-Duty Trucks Replaces: Caterpillar 1N4402; Citroen 95638903; Peugeot 110987 Thread: M20 x 1.5 O.D.: 3 11/16 (93.7) Length: 5 3/8 (136.5) I. Gskt.: G381-A UPC: 7 91440 03887 5
farmall
usa
Its just a plain old Chevy V8 filter. My next oil change I am going to see if the GM 2 qt. filter will fit.
juanprado
3,216
Metairie/La (N'awlins)
The list Coug post lists the correct present ac delco as the original post shows pf35 which was discontinued.
Main difference is they now have an anti drain back valve that the original production did not.
Whatever you choose...don't use Fram as they are absolutely garbage. Many YouTube videos show cut up demos.
Mogman
10,599
Papalote, TX
NO that filter has metric threads so it will not work, the correct filter will have 13/16-16 threads.
I have found the best place to cross over various filters is the WIX filter lookup, and those are the only filters that I have normally used for many decades.
You can start by looking up a 1995 HUMMER with diesel engine then you can use the cross to see if whatever filter you have crosses to the same Wix number, not totally foolproof but pretty close.
  • Like
Reactions: OBX
HAWKMAN
N.E. P.A.
Thanks for the answers! I still have like a hundred of these things left so all the help is appreciated!
T9000
370
California
I did a LOT of research on oil filters and given the design, media quality (fully synthetic) and high efficiency filtration ability down to 20-25u, the Purulator BOSS PBL34631 seems to be the best overall and that's what I am using on mine. Here are some YouTube reviews also, where they cut it open to analyze it and compare:
- 18,000 miles torture test with laboratory test results
T9000
370
California
And if you want to go beyond the product, like I do, Purulator is Made in U.S.A., owned and manufactured by Mann+Hummel, a German company with about 22,000 employees...Jawohl! lol
EDIT - btw, Mann+Hummel also manufactures the Wix and Motorcraft oil filters
EDIT 2 - and Mobil 1 oil filters are also made by Mann+Hummel, I have both and they look very similar, I installed the Purulator BOSS because of the
test results and also it is slightly heavier than the M1
