Hawk, here is the listing I found for that filter: ( I did a Fram cross)Wanted to check with the HUMMVEE guys if anyone would know if a Baldwin B7042 filter is correct for this vehical......I tried to Google and check online for info but didn't get anywhere. Thanks![]()
NO that filter has metric threads so it will not work, the correct filter will have 13/16-16 threads.Wanted to check with the HUMMVEE guys if anyone would know if a Baldwin B7042 filter is correct for this vehical......I tried to Google and check online for info but didn't get anywhere. Thanks![]()
Thanks for the answers! I still have like a hundred of these things left so all the help is appreciated!NO that filter has metric threads so it will not work, the correct filter will have 13/16-16 threads.
I have found the best place to cross over various filters is the WIX filter lookup, and those are the only filters that I have normally used for many decades.
You can start by looking up a 1995 HUMMER with diesel engine then you can use the cross to see if whatever filter you have crosses to the same Wix number, not totally foolproof but pretty close.
