Relay to turn on brake and turn signals with ignition on?
FlameRed
644
Florida
Hello,
Another newbie 92 M998 question.
I am trying to rig up a relay so that when I turn the ignition to run, I wanted to turn on the brake lights and turn signals without touching the light switch so I don't forget to turn them on.
For the turn signals, no problem, I found lead that Lead J off the light switch with circuit 467 was to flasher switch so the relay does now enable the turn signals when I turn the ignition to run.
But the brake lights are harder. I tried applying +24V to lead A circuit 75 which the diagram show as Stop Lamp Switch. No joy, the brake lights will not come on when the brakes are applied.
I also tried Lead K Circuit 75 which is also marked as Stop Lamp Switch - no joy.
I also tried Lead C circuit 22 labeled Stop Lights, but then the brake lights seem to come on when the brake pedal is not pressed.
Does anyone have any experience figuring out which leads off the light switch need to be activated to get the brake lights to work?
Thank you!
Mogman
10,459
Papalote, TX
Yes making 75A hot should give you brake lights, LET ME DOUBLE CHECK THAT
52
Aguanga, CA
Black Dog Customs makes a kit that accomplishes this already. The kit is $89 and pretty simple install.
Mogman
10,459
Papalote, TX
Looks like for the brake lights 75A is hot, I made this hot all the time so the brake lights would work no matter what position the run switch was in, you will also have to bypass the switch with wires 75B (K on the light switch) to 22A (C on the light switch) to get the 24V from the brake light switch to the turn signal switch. I removed all of these from the light switch so I would not back feed any other circuits and of course fused 75A
Mogman
10,459
Papalote, TX
467 from the light switch feeds the turn signals, I fused this to switched power so the turn signals would not be powered all the time, I think that also powers some other stuff on the later trucks so making it hot all the time may not be a good idea. That should also power the horn
Mogman
10,459
Papalote, TX
You could also isolate pin G (467) at the turn signal switch and fuse it hot all the time, this would make the turn signals "work" all the time but also it would allow the emergency flashers to be used no matter what position the run switch is in which may be a safety consideration.
which is one of the problems I see with the Back Dog kit, I want to be able to power my headlights with the run switch off if I want to.
It looks like all the BD kit does is switch all the power to the light switch (15A pin F) so you would have to run with the light switch in service drive or stoplight position, but none of the lights would work with the run switch off.
FlameRed
644
Florida
Looks like for the brake lights 75A is hot, I made this hot all the time so the brake lights would work no matter what position the run switch was in, you will also have to bypass the switch with wires 75B (K on the light switch) to 22A (C on the light switch) to get the 24V from the brake light switch to the turn signal switch. I removed all of these from the light switch so I would bot back feed any other circuits and of course fused 75A
Perfect! I was missing the 75B to 22A and now it works great! Thank you!
Guruman
Not so new member
494
1,074
Cody, Wyoming
I'm looking to do something similar to my lmtv. My plan was to disconnect the always on power feeding the light switch ("F" on the cannon connector in my case), and replace it with a switched power source. I could then leave my light switch "on" all the time, and the lights would power on and off with the truck. I would also retain the ability to use any setting on the switch once the power was on. Retaining my ability to turn off the lights or use the BO system if I wanted.
I got the idea from here and just modified what he did to make it fit my needs: https://builtmfg.com/2017/11/02/light-rewire/
What he did does not really directly relate to what I'm doing, but there is some good info there.
Edit: Here's a video of the linked procedure.
Mogman
10,459
Papalote, TX
[/QUOTE
Yes, just like I said in post #7 it is the easiest but no lights can be turned on with the truck turned off, somewhat of a safety issue and at times inconvenient.
Edit, lets say you are driving down the road at night and all of a sudden you have an issue with the engine, you reach over and turn off the run switch and you now have zero lights.
dmetalmiki
2,036
London England
I am puzzled..The lights should already function with the engine off?
It is a diesel truck so if you switched off the engine to check things the ignition COULD be left on..BUT SAFETY decrees that the 4 ways work at all times.
You break down, (On any vehicle created!) and you SHOULD be able to warn other road users (LAW vehicle type and construction). of this fact. With ignition/master switches on or off.
Army trucks have switching for Brake lights, Drive. Park. Convoy. Blackout. Blackout drive,
And one of those functions should give you the options you are looking for.
Well, they certainly do on all my ex military trucks.
Even my WW11 jeeps.
And not to be too 'pedantic..But You drive a car?..I mind you do not have a relay to operate either the flashers brake lights When the ignition is turned on?...In case..you..Forget??
Jus' my 1/2 penneth...soz if im incorrect.
Guruman
Not so new member
494
1,074
Cody, Wyoming
The hazards in my lmtv are activated by a toggle switch in the panel, which I'm assuming gets power all the time. Maybe I'm wrong, but I don't think changing the power feed to the switch would affect that.
@dmetalmiki For me, my issue is not with forgetting and leaving the lights on. It's forgetting and taking off leaving them OFF. My civilian rides do not require me to manually enable the stop and turn lights every time. For me that is much more of a hazard than needing to leave it switched on to use the hazards (if that were even required).
I'd much rather they come on by default than remain off by default. I can survive the humiliation of forgetting and looking like a dummy, even a ticket for it would not be the end of the world. But man, would I be sad if someone rear-ended my 18k pound truck and got hurt or killed because I forgot to operate the stupid levers. Fixing the all-lights off by default is high on my list.
Mogman
10,459
Papalote, TX
Like I said it is one of the easiest to do, but there are other ways also
Andyrv6av8r
458
Spartanburg,SC
I have a heavy duty relay on the positve battery lead contrlled by a keyed switch on the dash. I leave my light switch in the ON position always. Insert the key and turn on; lights are on. Then start the engine with the normal start button. I have used this setup in 5 trucks with no issues.
Coug
4,733
Olympia/WA
I just use a battery disconnect keyed switch near the doghouse. You can leave the light switch in any position you want and nothing will drain with the keyed switch turned to off.
Maxjeep1
1,930
Las Vegas Nevada
I have a start and stop routine that I always try to do in the same order. I very rarely forget to turn them on. I need to be able to drive without lights when I’m out poaching. Lol
Milcommoguy
2,396
Rosamond, CA
Poaching ?? on Las Vegas Blvd... Don't need lights.
Blinded by the lights, CAMO
