- 7,476
- 10,491
- Papalote, TX
What I meant was, you said at first it did not idle high, when did it start again (as the original owner stated it was idling high) after you installed the pump.It goes to high idle as soon as started. I have the throttle return as far back as it goes. I'm going to check return line to see if it's clogged.
I would be willing to bet ether there is rust in the gov. housing or somebody bent something in there trying to turn up the pump.
I have never seen a return line do that, usually runs like crap and barely idles, I am not sure why you are looking for an external problem as the seller told you is was not working correctly to begin with.
Would not matter that it was a 6.5L NA pump on a 6.2L as there is not a nickles worth of difference between them, not sure why you assumed that it would take more fuel to idle a 6.5L VS a 6.2L, there is only 300CC difference and basically the same engine and again not how the pump works anyway.
