- 2,186
- 87
- 48
- Zimmerman MN
I want to replace the giant canister/primary filter setup with a kit that will bolt right on to the three existing mounting holes and use a nice spin on fuel water separator filter . Any suggestions?
WOW very spendy. Thanks.Mvpartstore.com
Does the three mounting holes stand off enough to mount it direct or does a mount have to be fabbed?
FLEETGUARD FS1000 is a 10 micron fuel water seperator.
Fleetguard FS105 is a 20micron fuel filter
Fleetguard FS1001 is a 140 micron fuel filter
With the three filters in series does that cause any issues with the lift pump wearing out faster from the extra "work"?I would run an FS1000 and FF104/105.
I run a FF105, then FS1212, then a FS1000 on the pump just for longevity of filter life.
