- 179
- 105
- 43
- Wisconsin and Illinois
What type of water pump does the 6.5 A2 type engine take? This is serpentine belt.
Looks like it’s the pump with the bolt on pulley. See link.
flowkoolerwaterpumps.com
1992-1999 6.5L GM Chevy Hummer 6.5L Diesel flat hub CCW hi flow water pump
Flowkooler's 1677 pump fits the 1996-1999 395/6.5L Diesel. It has a CNC machined billet impeller designed with an increased vane count and a reduced impeller clearance to achieve greater flow rates, higher head pressure and a more efficient flow than other OEM water pumps. Type II Class II...
