blutow
- 501
- 63
- Austin, TX
I did the spindle nuts on my front hubs earlier this week. It was really easy and the hub cover is easy to remove by just taking out the 4 bolts and rotating the cover out since the steering linkage can articulate.
For the hubs on the rear wheels, I couldn't just move the cover aside since the suspension link doesn't bend that way. I was debating what the easiest approach is to get the rear cover out of the way. I figured it's either disconnecting the ball joint bolts holding the hub to to a-arm or maybe I could disconnect the suspension linkage from the rear hub cover by removing the bolt and banging it out. Any recommendations on best approach? I did find a couple videos online and neither of them talk about how to remove the rear covers (except telling me to remove the 4 bolts).
