T9000
- 370
- 63
- California
As I posted in another thread, one of the geared hubs drain plugs was stuck, the Allen key bent so much, I thought it will snap (it felt like 100 ft lb or even more). And with each pull, the drain plug head had more play...not good. I put some penetrating oil, but the whole thing is upside down and don't think it helped. Temporarily I pumped out as much oil as I was able thru the fill port and refilled with new oil.
I tried again last night and the fill plug allen head eventually stripped completely, Short of drilling the fill plug (as much as possible, I don't want to inject any shavings inside the hub, especially as the attached ferrite magnet will shatter when drilled), what options would you recommend? Hammer & Chisel? Ice/ torch to contract & expand then hit it again?
