RE: FDC
Hello WarCloud,
Im new around these parts.
I have read what you and other's have stated. I would like to add something else.
I was reading in another topic "FDC Pump" The person had questions about the F.D.C. and seem to referance it to the pump.
He wanted to reconnect it as well. But also stated it was worn out.
Long storie short. I finally understood what he was talking about.
So, I added my
You can read this in "FDC PUMP" topic
I came across some information months ago about, The LD, LDS, LTD,..etc 465 diesel engins on the WEST COAST. It was in a podcast I downloaded, For furture referance.
The engines had their F.D.C. by-passed &&&& the IP was retuned.
Yes, I do understand that the F.D.C., just doesn’t make the engine a multi-fuel. Its just one part in the works.
The main part would be the internal of the engine design.
The engines were retuned for better MPG & Emissions while running on diesel only.
The ones that were retuned should have a sticker or label. If it has not been removed.
For every action their is a equal an opposite reaction.
For the LDS-465-** engine to run on multi-fuels "same or a mix" over time.
Its not going to have the same power as if it were tuned for one fuel only.
Well, I gave this little info up and was SHOOT-DOWN by another member.
I understand what he had to say, And I agree because of were the information came from. Sort-of
If I read or hear of something. I just don't take it to hart. I research it. To understand it or to understand were others have gone wrong.
I hope to have the information in writting soon plus a Document stating, How to retune the engine back to factory settings.
If your interested, I still have the podcast.
What Im trying to say is.
Yes, Their might be something else wrong with the diesel engine to cause the symptoms stated in pass-submits.
But, If the engine was made to run with a F.D.C. and it is by-passed.
Some of the TM's information my not be useful in retuning for better MPG & Power, because the F.D.C. has been by-passed.
Then their is Muffys Law. If it can happen-It can. Some LDS-465 engins may just run perfect with out the F.D.C. and running other fuels.
Injoy!
