LM/FMTV TURN SIGNAL /HIGH BEAM SWITCH ?
chucky
19,261
TN .
Has anyone tried to cross referance the turn signal arm/ what ever you call it on the steering wheel to probably goes on fifty other trucks for 75 bucks instead of 435 bucks there is bound to be used on regular commercial trucks and a pile of them in a big truck salvage yard if we knew where to start looking ?????????????
chucky
19,261
TN .
I would get a new one. I have tried used ones without much luck
Copy that ! I try to make my little bag of pennies work as hard as they can for me when i can ! Is there a certain place to start on the 170 ones? And THANKS for the info
serpico760
1,881
San Diego, CA
Nice now I just got to find a distributor of the dashboard switches who will actually contact me back!
Sent from my S62 Pro using Tapatalk
chucky
19,261
TN .
Ive found the right part numbers i beleave and can buy them from $10 to $20 a piece new but have to order 40 units so tomorrow when truck world is back at work i will let them run with these part numbers and i will report back !
serpico760
1,881
San Diego, CA
Do they have to be all the same switches or can they be some of these and some of those? several of my switches have broken tabs and are flopping all over the place
serpico760
1,881
San Diego, CA
The switch legends pop out. I got a Chinese knockoff blinker switch they aren’t expensive but the plugs are different
Cool I was trying to figure out how to pop those out but hadn't discovered the trick yet. Of course some of the switches are two-way switches some of them are one way and some of them are momentary.
Third From Texas
6,662
Corpus Christi Texas
