- 168
- 326
- 63
- Central Florida
Unknown on the gen working or not. Still chasing wiring for the governor circuit, and i just found the procedure to engage the pto on SS.Thats is a good starter...does the generator still work?
.I have also determined that the generator does work.
If it's urethane, as in polyurethane, it should come off with some paint thinner or other chemicals of the like. Spray some thinner on there and then wipe it with a shop cloth and see if it comes right off. Usually that stuff will cling and gum up sand paper and stuff.I have tried the heat gun. Stripping wheel does much better. The red paint appears to be urethane. It melts as it is being sanded.
