CUCV Cooling System Upgrade Kit
darylwiz
Orange County California
Guys, you may have seen the kits I build for the HMMWVs 6.2, 6.5 and 6.5T which reduces the overall system temps and balances the overall block temps. You will have less fan on time and more power as a result. Longetivity will be improved significantly as well. The side benefit of the kit is reducing the cabin temps as the rear of these blocks runs much hotter than the front.
The issue is that the system will not fit the same due to the difference in the CUCV and the HMMWV coolant crossover pipe. I have developed a different system but I need a guinea pig. So for the first taker the kit will be $200 vs the normal $250. If the kit needs to be reworked you will get the reworked kit. I am 99% sure this will fit correctly but I dont have a CUCV right now to verify.
Below are pics of the HMMWV kits. Several SS members have the kits and they are working great.
View attachment 678174View attachment 678175View attachment 678176View attachment 678177View attachment 678178
Hi Joe,
I was curiou, do you own Paradox?
I want to order your kit, tho I need 4 Gaskets, the 2 up front at the crossover tube need to be replaced..
Can I order your kit with two extra gaskets?
911joeblow
72
Utah
Hi Joe,
I am Derrek. Not to be too confusing but we also have a Joe in the shop :). If you want to place the order online just add a note and we can add the gaskets. They are NOT expensive. We will just invoice you the difference that you can pay with a click.
deank
679
Inverness, Florida
I know this is an old thread, but people still look at it. Like @kieth_j I also have an M1031 that I installed the paradox by design kit. Here is how mine looks. Because of the engine governor I ran the hose below the intake. To connect the hoses I had to add 2 each 90 degree AN fittings.
