15w40 synthetic is hard to find. Usually only by Lucas.Is it ok to change to 15-40 pure synthetic oil in my 8.3 Cummins ?
You're almost certainly going to time out the oil before you wear out the oil. Thus the extended drain interval on the synthetic doesn't really help you.Is it ok to change to 15-40 pure synthetic oil in my 8.3 Cummins ?
Rotella makes a synthetic 15w40. I use it in my dirt bikes.15w40 synthetic is hard to find. Usually only by Lucas.
5w40 synthetic is more common which will make it rattle.
Like I said. It is hard to find. You might find 1 or 2 of them but doubtful you are going to find 8 to 11 gallons of it at one location. Napa carries usually 2 cases of Lucas 15W40 as it is a common stock for them.Rotella makes a synthetic 15w40. I use it in my dirt bikes.
I stay away from Rotella due to the low emission ZDDP content that at one point was destroying the cams on Ford 6.7s. Im not sure since then Rotella changed the formula but I do remember that Chevron had to discontinue one of their diesel oils that I bought $20 for 5 gal once at walmart because their zddp was way too low. I simply added $5 worth of Zddp in each and was good to goYou're almost certainly going to time out the oil before you wear out the oil. Thus the extended drain interval on the synthetic doesn't really help you.
My opinion, with a history of being nearly OCD on oil selection, is that the best choice for diesel MVs is any decent oil (I use Rotella 15w40) changed frequently.
I thought that Napa/Wix filters were the best after seeing a test but when Adeptape on youtube opened them and showed the crappy worksmanship of their regular white cannisters I was horrified.And IMHO if its a CAT motor put CAT filters on it dont be cheap on this part !
You will have to cross your cummins filter number over to see if Cat makes anything to fit it or cal a big truck parts counter and see if they can cross it ! AFSI makes 80% of all Cat filters see if they make filters for your cummins .I thought that Napa/Wix filters were the best after seeing a test but when Adeptape on youtube opened them and showed the crappy worksmanship of their regular white cannisters I was horrified.
I wish I could find Mann filters for my M923 if anyone knows which model it is. I tried looking but no bueno so far. Are cat filter proprietary and not fitting cummins?
