- 84
- 12
- 8
- Natchitoches, Louisiana
my m931a2 transfer case shifts into low - grinds when engaging transmission and immediately kicks out
undo the linkage and checm that it physically locking into low range all the way out.my m931a2 transfer case shifts into low - grinds when engaging transmission and immediately kicks out
You would be better off going to 24R21s. They are very wide for flotation. Wheels are available.I am the same guy who asked what a combat wheel was. Still trying to dual up rear wheels on m931a2 converted to dump truck. Same truck has low range problem.
You would run a 1600R20 up front. Same height as 24r21s but half the width.Fronts also?
YesWill the wheels bolt directly to M929a2 and m931a2 axles without any modification
I have a few good take out transfer cases if you are in the market for one.The low range will only engage the clutch. Will not seat into gears. Will remove case and repair.
I've only put a shift fork in one. Most of them bust the case so there isn't anything to repair.Have you repaired any and what are you asking for 1?
$2500 and that includes shipping to you.
