Glider
- 227
- 43
- South Pittsburg, TN
Painted, Still need pin for handle. Next will be the spare.
Easy to find. You can use the square or half moon lock pins. Home depot, Lowes, tractor Supply. OE also uses a metal wire rope crimped on both ends on to the pin assembly so it does not get misplaced. Also easy to make with stuff from Home Depot or lowes.Painted, Still need pin for handle. Next will be the spare.
.What, too afraid Action to use the Airlift system?
(Awesome pics!!!!!)
Amazing!!! Those are incredible pictures. Let me know if your friend can get anymore of those doors.Did a few pics with a friend’s truck...
I cant tell from your pic, but do you have the bracket on top that holds the fan shroud off of the fan?Adjusted cooling stack positioning per TM to resolve an interference issue with the fan. Had to remove the side panels to fully access the two rear upper radiator struts. Fairly easy after removing the panels.
Did you have to cut your b-pillar off a little bit?Pulled the installed Red Dot A/C components and hoses. Capped and left compressor on engine for now.
Started installing Plan B hard top and back curtain. All aluminum parts are CNC cut and fit well. Some easy riveting and rivet nut installation required. Very complete kit; Plan B even included a pneumatic rivet gun and the rivet nut arbors.
No, I did not have to touch the B-pillar. I had to loosen the passenger side of the A-pillar hinge a bit to square it with the roof.Did you have to cut your b-pillar off a little bit?
Really nice!No, I did not have to touch the B-pillar. I had to loosen the passenger side of the A-pillar hinge a bit to square it with the roof.
