What have you done to your HMMWV today/lately
juanprado
3,166
Metairie/La (N'awlins)
Painted, Still need pin for handle. Next will be the spare.
Easy to find. You can use the square or half moon lock pins. Home depot, Lowes, tractor Supply. OE also uses a metal wire rope crimped on both ends on to the pin assembly so it does not get misplaced. Also easy to make with stuff from Home Depot or lowes.
I also had another pin at the ratchet handle hole wire roped as a spare.
I don't remember the sizes off hand but it this style set up:
rcamacho
914
Bainbridge Island Wa
Adjusted cooling stack positioning per TM to resolve an interference issue with the fan. Had to remove the side panels to fully access the two rear upper radiator struts. Fairly easy after removing the panels.
Action
1,564
East Tennessee
I cant tell from your pic, but do you have the bracket on top that holds the fan shroud off of the fan?
The shroud also has slotted holes, so it can be moved up and down on the radiator.
Sigi
82
Portland/OR
Pulled the installed Red Dot A/C components and hoses. Capped and left compressor on engine for now.
Started installing Plan B hard top and back curtain. All aluminum parts are CNC cut and fit well. Some easy riveting and rivet nut installation required. Very complete kit; Plan B even included a pneumatic rivet gun and the rivet nut arbors.
Maxjeep1
1,930
Las Vegas Nevada
Did you have to cut your b-pillar off a little bit?
TOBASH
3,920
Brooklyn, NY
I don't understand people who remove A/C, BUT that compressor is used by many offroad drivers to air up tires. just add fittings for air filtration and appropriate hoses.
HoveringHMMWV
1,346
AL
Although cosmetic in nature, I started adding 3/8" socket button head screws w/ washers to fill in the holes left by the demil process. I also included rubber washers under each backside steel washer to hopefully make them water/moisture proof. I started the process by priming and painting all of the individual components. I chose the 3/8" size because they would fit under the door hinges without impeding their function.
