Power Brake Booster Leak
adf5565
688
Tioga, PA
I just noticed that I’m getting a leak of power steering fluid from the brake booster right where it bolts to the master cylinder. I just replaced both of these with rebuilt parts a few months ago and have put maybe 15-20 miles on them. Did I just get a lemon of a rebuit booster? Or am I missing something? 6CF6FC81-1E15-4038-A95F-2A0B6905FAE1.jpeg
cucvrus
10,433
Jonestown Pennsylvania
Are you certain that it is power steering fluid. And did you use power steering fluid. I always use power steering fluid. I see guys use ATF and that is not what came from the factory. That is not as thick as Power steering fluid. 1656580600410.png Another thing that I noticed is that the new brake master cylinders are stamped for DOT 3 fluid and I put DOT 5 in them. Not sure if there is a difference in the seals. Good Luck.
adf5565
688
Tioga, PA
Are you certain that it is power steering fluid. And did you use power steering fluid. I always use power steering fluid. I see guys use ATF and that is not what came from the factory. That is not as thick as Power steering fluid. View attachment 871873 Another thing that I noticed is that the new brake master cylinders are stamped for DOT 3 fluid and I put DOT 5 in them. Not sure if there is a difference in the seals. Good Luck.
Yeah I’m pretty sure it’s power steering fluid that is leaking. I did use DOT 5 for the brake fluid which from Napa has a purple color. The fluid I have leaking is clear and I’ve also had to top off the power steering reservoir. I didn’t use ATF. The leak is pretty significant, with the vehicle started and push/holding the brake for 5 seconds cause it to have noticeable fluid on the underside with a drip or two. I’ve checked hose connections as well and they’re tight with no signs of leaks.
I was able to get a warranty replacement for the booster so hopefully I have better luck with this one.
LT67
501
Bowdon, GA
Could be your hydro boost unit...
The hydro boost unit on my 86 M1008 has a slight leak and needs to be replaced
