M1061a1 restoration
muthkw25
740
Canton, PA
Today I finished painting the trailer. Got 2 coats of marine corps forest green (34052) on the trailer. Added new reflectors and stainless steel hardware. Painted glad hands. Removed tape from data plates. Shined the tires. Trailer looks as new as its going to get. Very pleased with the project. Turned out great.
muthkw25
740
Canton, PA
Today I finished the emergency tank drain pull cable. Bought 3/32 steel cable and a swaging tool and finished up the trailer. Took it on its first voyage and picked up a large number of US army pallets. (These were not light.) Trailer did great. No wagging or pulling to either direction brakes worked well. No issues with drums heating up or hubs. Very pleased with the results. Will add some additional tie downs in near future as well. Overall it was a good, quick restoration and trailer is back to functioning properly.
20,688
Nice!
And having a way to easily drain the air tank is a big plus. If it is easy, there is no reason not to drain it. If you have to get dirty and crawl in on your back - it gets left for another day.
Good Plan @muthkw25 !
muthkw25
740
Canton, PA
Cool! I'd like to get one of these for a shelter to go on.
I have also thought of this plan. Originally looked at a s280 but I'm now really considering putting my s250 on it and using that for sleeping in and then the rest of the space as a deck for my girlfriends and mine m274a2 mule to strap down for camping and shows and then when the mules not on the deck I can use it as a deck to set chairs on etc.
muthkw25
740
Canton, PA
Today I moved my dads ford compact diesel tractor on the m1061a1 back home. Drove great behind the truck. Truck did great at 50 mph. Trailer has had alot of use since finishing it.
CallMeColt
1,715
Wilson County, Texas
An S-788 would be good for this idea. Then, if you have a tractor or something, you can make it removable. S-788 has much more room without much more of a footprint.
muthkw25
740
Canton, PA
I am looking at replacing the original tires with new ones. I don't like some of the stress cracks from age. Has anyone replaced their tires on their m1061a1? If so what company did you go with.
muthkw25
740
Canton, PA
I bought a s-250g to fit on the m1061a1. I wanted the larger version of the shelter for camping. Came with a fridge, electric and ac. Shelter is in fantastic shape. I decided to mount the shelter approx 2ft back from the front edge of the deck. I wanted some extra storage space for boxes, generator etc and less chance of hitting back of the truck when turning. This gives me 4ft on the back where I can add 2 chairs and sit on the deck.
Attached are some photos of moving the shelter onto the trailer.
The shelter has since been rotated so the door faces to the rear. I tried getting a photo of the shelter fully locked out on a turn to show there's plenty of space for the ac to not hit the back of the truck.
Originally I thought about having the shelter door face the back of the truck but I didn't want to push the shelter to the back of the trailer to utilize the deck space.
Plan is to paint it marine corps forest green to match and add a RV roof coating to reflect heat for the warm months when camping.
muthkw25
740
Canton, PA
I was trying to figure out a way to secure the shelter and decided to use some eyelift points with steel cables.
I centered the shelter on the trailer and then drilled a 3/4" hole for the eyelift. Centered it on both sides. I'm going to use 1/2 turn buckles. It will require 5ft-3/8" steel cables. I wanted one tie down spot on either side so ill have each top corner going to a central point.
muthkw25
740
Canton, PA
I got the eyelifts bolted down and got some 5ft long 3/8" steel cables to some 1/2"- 6 inch long turn buckles. All 4 tightened down. I'm going to add some pressure treated 2x4s and have them bolted down on either side to keep any side to side shifting from happening. Next is to start the prep for the shelter paint.
I'm adding Henry tropicool to the roof. This will drop temps inside the shelter and will protect and seal the roof from any potential water leaks.
muthkw25
740
Canton, PA
Started sanding the shelter for paint. Cut 2-2x4s and used the pre-existing holes along each side of the shelter. 5-1/2" holes.
Used stainless steel hardware. Primed and painted the 2x4s.
Now shelter is supported so it can't shift left or right.
marchplumber
3,414
Peoria, Illinois
Did i see duals on front of five ton? Im old, sooo eye sight aint greatest. How'd you load compact tractor on trailer? Removable ramps? GOOD JOB and WELL DONE, Sir!
muthkw25
740
Canton, PA
No duals on the front of the 5 ton. 395s all around. We had a ramp to load the tractor off the back of a little hill. Used some steel and old m35a2c drop sides that were bad.
Thank you!
