Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
28 also goes through part of the steering column mount, they do not show the others going through the firewall ether..
The same bolt also holds a cable clamp, that is a parts diagram not a service procedure.
@Mogman how in the world does a person get to the nut behind the (2) 27 bolts. When I'm trying to take out 27, in true HMMWV fashion, it just spins and spins
It's these 2 bolts to the left that refuse to come out. With no access to the nut in the back I'll have to cut them out which I really didn't want to do.
Even in cutting the heads off the bolts, the shanks will fall behind in that box and rattle around forever. But these 2 bolts hold the dash in.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
